Hi guys,
I am having a bit of a nightmare with my watercooling atm. I have always used 7/16 x 5/8 tubing that has worked great in conjuntion with my Bitspower compression fittings 7/16 x 5/8.
However I have decided to fit some Koolance quick disconnects to the graphics card block to allow for easy dismantling.
Now this is where my problem starts. I purchased the male and female QDC3's (part number F13X16) which are meant for 1/2 x 5/8 (wall thickness 1/16) tubing.
I thought I might be able to use my 7/16 x 5/8 tubing but the wall thickness is too much and I cant screw the clamp on.
I dont really want to replace all my Bitspower fittings as it will get very expensive and was hoping someone could assist me.
If I could find 1/2" ID, 5/8" OD Wall thickness 1/16" tubing in the UK I think it might work.
Please help.
Please help.
