NeverBackDown
AMD Enthusiast
Intel's ITX Z270 boards are only sata 3 M.2 and X4 M.2.
There is no dual x4. You lose half your sata on ITX by using 2 M.2 slots. Is it worth losing essentially 2 sata ports? Not really.
Outside that, the other things are preferences. The BIOS's will be similar from brand to brand and if USB is a high priority, you can always buy a USB hub or get a GPU that has VR plug ins in the end of the card.
But it sounds like you just want intel and you are convincing yourself to get it. So just do it if you are more comfortable with that.
