Hi.
I'm putting together a dual loop water setup in an STC-T01, using 1x BIP-360 Rad in the bottom & 2x 120 Rads, back & top (unknown brand but thicker than the BIP). The entire system will be piped out with 1/2" Clearflex & 1/2" EK barbs. I plan to cool the following heat sources:
* E6300 (Apogee GT)
* LANParty UT ICFX3200-T2R/G - Northbridge (DDMaze4-Intel) , Southbridge (DDMaze4-Intel) & Mosfets (MIPS MCH143)
* X1950XTX (EK-FCX1900) - With possibility of adding a 2nd for Crossfire later
* Danger Den Aquadrive
I will be hooking up Yate Loon D12SL-12's to all the rads, 5 in total all connected to fan controllers. Just received a couple of black Scythe Kaze-Master's & they look the nutts. I also have one spare DDC 10W and a spare D4. I'll probably end up using these unless there's some special reason why I shouldn't. For the res I have a few choices open to me, i'll decide on that later.
Guess I have a few questions to shoot really:
1. Do I have enough capacity in those rads to deal with the heat dump?
2. How should I best divide the load between the three rads?
3. Which pumps should be used for each loop?
Any help from anyone would be sincerely appreciated. Thanks guys!
* E6300 (Apogee GT)
