Does anyone know where I can get one from? All I need it to do is look like a button and be able to be pushed in. i have the small switch that sits behind it that will connect to the motherboard and power the pc on.
If you want to go el cheapo the simplest would be to take an old case and take it out. I'm sure there's some old P4 case from work or anything that isn't being used anymore.
