SuB
The Webmaster
ok to set the scene.. i think my lovely 8800GTS 640mb... has had it :S
(skip if you like)
I'm pretty sure the stream processors are up the duff...
i first played crysis and it was 'reasonable' after the whole ending water scene that totally killed everything.. i thought ok.. i'll try an overclock.
anyway after some tweaking of all speeds in rivatuner it sort of hit a point where it just got worse?
anyway even at stock now.. whenever i look at 'water' in crysis it completely kills the fps.. i mean like.. VERY badly
asif the shaders are b0rked or something.
also playing CoH.. full screen it stutters ALOT, then windowed at the same resolution its suddenly fine.. but still a little sketchy i guess :S which seems odd..
also crashes alot
deffinately video card crashes as the pc is still sorta running.. but there is a black screen.
the long and the short of it is.
what should i go for?
say a budget of around £200~£250
8800gt? another 8800gts? an 8800gtx or push into the 9800 series?
(i don't want anything involving x2 or sli) just want to play my games at 1920x1200 (if possible)
also i'd like to include it in a 1/2" ID watercooled setup so waterblock availability is a must really..
cheers guys just can't decided what to get.
SuB
(skip if you like)
also crashes alot
SuB
