Need a case ASAP help!!!
mbmapit44
Here are my requirements:
Full Tower
Spacious (room for cable tidying would be nice)
MUST NOT BE BTX!!!
Very good airflow
Preferably room for watercooling
Please don't suggest:
Coolermaster Stacker
Lian-Li V2000
I looked at the new PC-G70 but can't find any reviews or any stores that stock it.
I'm using Silverstone Temjin TJ05 case... In my view it's very nice case and will meet all your needs (even enough space for water cooling).
Check review's:
http://www.moditory.com/content/view/86/34/
http://www.ap0calypse.com/showthread.php?t=2178
http://www.hardcoreware.net/reviews/review-242-1.htm
http://www.avault.com/hardware/getreview.asp?review=tj05
http://www.techwarelabs.com/reviews/cases/sundialmicro/
There is no perfect case in world, but i'm happy with this one, and only letdown for me is 2 fited 120mm fans (front and rear), they are a bit noisy, but you could change them with, for example, AKASA Amber 120mm or any another low noise rated fan's.
Be ware that there is couple different models around (with side window and without, with front LCD panel and without and 2 types of color-silver or black).
My case is reviewed @ 1st link i gave you and comes in black with no side window and no front LCD panel.
Contact me if you have any questions.
Cheerz!
I'm a big fan of the Lian-Li range. They have a large amount of new ones soon to be released - have a look on the official site, and you'll see what they have to offer :)
@ BigAndy - Please could you edit your post to remove the competitor link...
I know the PC=G70 looks great but nobody has it yet?!
Thanks for the ideas guys but i need a full tower so only recommendations of those please (but not BTX).
Also like i said a place to hide wires would be very nice to have.
I know i'm asking a lot but there must be a case that exists to fit my requirements.
chris_ah1 said:
PC7077 is a nice case.
what about the aerocool masstige?
No offence but that's basically a stacker but worse. By using the ATX backplate would mean i have to get my power cables all the way to the top of the case, so would look very untidy.
As Mav said, the Lian-Li PC7077 is nice and Phil could make it individual for you :)
How come you don't want BTX, are you sure, the Lian-Li V2000 is a very attractive case with great airflow. I'm sure with a bit of work it could be converted into ATX - and you'd also get 'Modding Legend' status! :B
I have the V2100B at the moment and hate it. I just think the airflow is horrible. I need at least some air flowing over the motherboard.
