Phil Stanbridge
Just a little something for this watercooling gallery.
My PC75 - with two 120mm blowholes for the thermochill 120.2, an 80mm blowhole for the res, a custom cut in the hd caddy for the Enheim 1250, UV green tubing (that needs a little shortening), a RBX DD cpu block, and a Maze 4 gpu block.
Good temps too with my 53.
40 degrees idle, 55 degrees under load.
Rad 9800XT is 60 degrees under load.
water is 30 degrees average
