My old Haf 932 - Upgrades planned
Noobnerd
Here is how my setup used to be
specs are in sig
Old rig
New loop
UV leds
Im planning some upgrades that im still deciding on. I do plan on using a dif case and a shorter loop. Also gonna change the color scheme as this did not quite turn out how i wanted it to. Kinda just threw it together quick as i needed if for online classes. I am planning upgrades inspired by TTL vids.
CM Haf 932 case, ASUS Crosshair V formula, AMD 1090t, Corsair Vengeance ram - 8gb @ 1600, XFX Radeon HD 6870, Corsair TX850M power supply.
Loop is XSPC raystorm CPU block, XSPC ex360 rad, and XSPC dual bay res with D5 pump(old style).
Currently running at 17 degrees celsius at idle and around 30 degrees at load. i havent adjusted for crappy temp sensors in the 1090t....so ive heard.
