My Switch 810 Rig Gallery ("Loxley")
joesaiditstrue
Hello, this is my first post on the OC3D forums, I hope you enjoy the pics of my current build.
First is a list of the hardware, followed by the images. Forgive the picture quality, poor background lighting and only using the iPhone 4 camera
Core i7-2600k @ 4.7
16GB Corsair XMS3 DDR3-2000
Asus P8Z68-V/GEN3
MSI HD7970 Reference
Plextor M3 (128GB)
2xHitachi 1TB (RAID0)
WD Green 2TB
NZXT SWITCH 810 White
Radiators:
XSPC RX360
Alphacool UT60 (240mm)
Pumps & Reservoir:
2x Swiftech MCP655-B, Alphacool Dual Liang D5 Bay Reservoir
Blocks:
XSPC Raystorm
EK-FC7970 Nickel+Acetal
Etc.:
Corsair HX1000, Feser White UV Tubing (1/2"ID x 3/4"OD), Feser Black Tubing (1/2" ID x 3/4" OD)7x XSPC 1650RPM 120mm Fans, 3x Scythe GT AP-15 120mm, 2x NZXT 140mm Performance, Compression Fittings (XSPC & Monsoon), Bitspower & Alphacool 90' Fittings, Extenders, Phobya 30' Rotary Fittings, Modsmart & Bitfenix Alchemy sleeved extensions, Scythe Kaze Q-12 Fan Controller
The name "Loxley" is because I really enjoy the Robin Hood storyline, and use this name in a lot of videogames that I play (Diablo 3, FFXIV, Dark Souls, etc.)
Thanks for looking, criticism is always encouraged!
looks awesome but like many other people i'm sure we wanna see an inside shot with the side panel off
Be warned if you do go and remove the stickers you will have a sticky resin that is hard to remove, you're better off leaving them on if that is what YOU like since it is YOUR rig.
I think it looks great neat and short loops. It would be cool if we could get a picture of the interior with the door off and the lighting off so we can see the guts more clearly.
Arctic silver thermal paste remover does a great job removing that sticky resin.
added interior shots, updated the inlets/outlets of the bay reservoir photo as I re-routed the black and red cables coming from the pump. badge stickers are gone
Looks pretty amazing mate
i have yet to attempt watercooling, my cpu is watercooled but it was a premade kit (Antec Kuhler)
Hi there,
I loved your system. It almost made me want to change my Haf-X for the 810 lol.
I got very impressed on how clean it is. I was wondering, could you take a picture of the back of the motherboard tray?? I wanted to see the water cooling in the back. I think that was very smart XD
I was thinking on trying that on my HAF-X but I dont know if I have enought space.
Thanks.
Ralm, I'll post a pic of the wire management and mb tray tonight, sad story.... 7970 decided to die last night for no particular reason, sigh
