youpla
Well as a new member I thought I could introduce my system with a few pictures.
I changed the default NB heatsink for a Zalman NB47J. The problem was that I couldn't use the push-pin system that came with the NB47J cause the motherboard didn't have holes. I had to use the metallic hinge from the default heatsink instead and it seems to do the trick.
Here you can see how small everything is. The NB47J, the RAM heatsink and the ICE system on top of the CPU. Missing are the rack with DVD drive, floppy and SD/MS/CF reader. And of course the 2 HDs on top of that.
And finally a shot of my little space...
