My Phantom
Deathtrip2k
Here's my rig:
Asus P5Q Pro Turbo
Intel Core 2 Quad Q6600 2.4ghz @ 3.6ghz (1.5v)
Noctua NH-D14
Gigabyte GTX 460 OC 1gb @ 850/1700/1950 @ stock volt
4gb 800mhz ram 1:1
600w Plexigear 80+
(yes i know, not the best quality pictures)
I need to get a longer SATA cable so i can run it throug the upper cable management hole
I will also get some sleeved cables, or sleeve them myself tough im not quite sure what color i want. Either black or white. What do you guys think?!
Last but not least, i will buy a 200x200x20mm fan and see if it will fit on the side panel together with the massive NH-D14
