my modding Apple Case G5 by IgNOrE
.ignore
my web site
http://ignore.com.ua/mysitedb/index.php?id=57
I would like to have for a long time barnd the case siemence or apple
But the case is problematic to buy on ukraine in kiev
I managed to get it for 150$ it in firm selling apple
In service the centre (in a tolerable condition)
I have started to look that is as the people alter about my look have stopped on this companion Cyprio (S.Stavrou's).
http://forum.overclock3d.net/showthread.php?12600-Apple-Core-Duo-Case-Mod-Worklog
All the rest not seemed to me interesting
Here at this forum
You can see a full picture as its case Cyprio (S.Stavrou's) became
The tool which it is necessary for Moddinga of the case:
1 Screw-driver Т8
2 Dremel original from bosch approximately 180-220$ depend on a complete set
Or Chinese типаENHEL but it is obligatory with flexible extension
3 Flat grinder small square type the such
4 Hammer
5 anvil
6 Epoksidnuju pitch + Aluminium powder a jar where awake to mix components
7 Fiber glass fabric
8 Drill
9 Points
10 Ground for painting
11 Paint
12 Case Shieftec model ba-01b-b-b approximately 120-130$ with a power unit
http://www.chieftec.com/ba-01b-b-b.html
13 Skotch
14 Painting tape
15 Djurelevyj sheet on a thickness of the case (on обявлению it was possible to buy the smallest from me кист 3м*1,5м to me it have cut on at a part)
16 Metal ruler
17 Sandpaper
18 Small screws
19 Rivets
Where you awake 20 Place to work
21 Brains and equal hands)))
Only 21 subject
If that has forgotten be guided.
Pictures of my case has not remained the case was approximately here such kind.
Here the case
url]
It has seemed to me интиресен from for good iron (тяжерый) and qualities of assemblage.
box Сhieftec
case Сhieftec
Front cover
Mean Сhieftec
Seats in Сhieftec for hdd
My older Сhieftec nearby)))
We drill rivets in Сhieftec for the back panel
The removed back panel from Сhieftec for Apple case G5
We try on as will look Modding G5
I would glue a painting tape for this purpose that a pencil to put a line for a cutting
Useful expensive thing
I start to cut off not necessary in Apple
I look as panel Shieftec in G5 will look
I remove fixture hdd
There were some variants how inside better to attach a plate
1 to Solder aluminium
But
Planes do of duralumin but them do not solder them rivet rivets
2 Argonovaja welding
3 On rivets to me not позалось that it will be beautiful
4 Tried воспользоватса (Cold welding) it was not pleasant me a two-componental thing has not seemed to the reliable
5 Has stopped on Glue EDP (Epoksidnoj to Pitch)
And this soldering iron a tomahawk))) looks as an axe
Cut out a new piece of duralumin for the case
Here points
Good brush for paint removal on cars with plastic setae
Tried to polish has looked as the unsuccessful idea will look in due course polishing will grow dull better to paint and varnish it will be better to look
Here I handsome and on a back background partially smoothed out middle of the case
Tried to take advantage cold steel
It looks here and goes in one tube of type of sausage
The result of work approximately here looks and there is no reliability of such connection does not stick and nearby is fastened epoxy
Painting tape for when awake to fill in epoxy what it has not escaped anywhere
Just in case I glue atop Scotch tape on a tape
Here is how выгядет which I use fiber glass fabric
It is cut by usual scissors.
ATTENTION when cut fiber glass fabric that do it not indoors when slices get to an organism they do not decay.
Pictures at me has not remained as I glued epoxy plates in the case
In brief history
Take a film (I took that which sandwiches turn more precisely that which on flights the goods braid)
Further высыпете aluminium powder 2 parts to 1 part in already смешанно epoxy
Further pour epoxy in the case
From a paper cut out a template of a hole of the back panel of the case
From lateral aspect on bored through half of holes
We look where it is necessary to drill holes for rivets
We look as the case looks with computer payments
I recommend here such mill to buy it it is very convenient
ATTENTION work wearing spectacles and on small turns 5000 differently the mill will break away bought approximately for 8-10$
Has planned a pencil of a hole in the case has drilled a drill and then already by this mill did the necessary size for rivets
File has levelled edges
Here is how rivets of 4 mm look
Here such sandpaper has levelled a rivet surface looks very exactly
Accessories on the forward panel
Today 21-jan-2010
The rest I will lay out when I will make
//today 09-apr-2010 and yesterday has found time to continue with the case
Has left on holes of hours 10 where that
Rivets have strongly helped thrust in a hole and at the good equal line one in parallel another by means of a ruler turns out
(By the way see break top a funnel in one of holes it when ream after small diameter on big here such can will turn out so I recommend holes ream the big drill from the inside)
It is not so successful variant was
punch has filled labels crookedly that as fun fun))) has turned out)))
Here and I speak that has crookedly turned out
But lines equal have turned out
Variant of 2 rivets have strongly helped
Here they
Well that's where it so
For this сеточку a marker has spent hour one and a half precisely neck tonight is ill for 2-va day of work
It a drill has vertically tried
It at an angle
It I in sea fight play a dagger)))
When filled all merges on these lines of pieces 5 by has knocked
And here it is visible as at an angle a drill has planned it has not bad turned out
Here a drill
Aha the interesting moment
At me a grip in a clip normally diameter holds those a drill is strong clamped and in the end a grip more in diameter and the drill starts to vibrate what it did not occur and in a grip strong all kept I reeled up a foil
It is necessary to buy on diameter that the drill and a grip coincided
But there where I bought from them there is no such grip it was necessary to subtilize
On drilled small holes and then from the inside expanded a hole in the big diameter
Shavings the whole scoop has turned out that dust there hardly hardly
Here the highlight of the program)))
Well where that so here all has had time to make today
Here with has missed a chance so it is corners it was necessary to do roundish and and an aluminium piece to leave
I have already thought up as to solve in this question I a figured piece of plastic I will cut out on perimetre and from above I will impose and on perpendicular to it in depth too
First of all welcome to the forums dude, secondly thankyou for reposting in English.
Epic work btw dude, looks awesome.
Awesome looking mod. Thanks for the repost, my cyrillic is really rusty. Can't wait for some more pics.
Process goes not quickly
In process of work I will be upload a photo
In the near future I plan to make the front panel (usb power fireware)
And fixture for mb
And it is idea to make edge from a corner
And where to find such hours unless on tokyoflash))) http://www.tokyoflash.com/en/watches/1/
Appearance of the case is lost if to put LCD + card reader
I abandon to the idea to leave the button power on the place
And to put 2 usb + 1 fireware
Instead of ear-phones to put the second USB
Dude...you have some good planning out ideas there man. Looking LUSH!!! I cant wait to see the inside done. This is going to be gooooood. We need a good mod on here atm...CANT WAIT!!!!!!!!!!!!!!!!!!!
