my gaming setup
jakedizzle
so here is my setup. it does everything i need it to. tell me wat yea think.
i will just post my rig stuff on this thread.
my specs are:
core i7 920 @ 3.4 with zalman 9700 cooler
evga x58 classified
6gb corsair dominator gt 1600 memory
thermaltake toughpower 1000w
tagan A+ black pearl case
windows 7
300gb raptor hd
74gb raptor hd
320gb hd
500gb hd
6 120mm fans
2 80mm fans
24inch gateway widescreen monitor
19inch secondary monitor
yea this case wat tagan remake of the lian li v2000 the first edition one. i wanna get a new case cause this one i have had for awhile. i think its time for somethin new. what do u guys think i should get.
Whats your budget? I'd say get an ATCS 840 and have tom cut a window in it + spray it's internals black...
oh i will check that out. but the sending it to tom would be alittle expensive since i live in the us. haha shipping with kill.
dont really have a budget either. just watever looks good but not ridiculously expensive. i was thinking maybe a antec 1200 but everybody has one. i like the look of them though
yea i wanna take it apart and paint it all black. its been green for awhile now. just gunna be a pain sanding all the green off.
haha I totally didn't know it was painted green inside I honestly thought it was the lighting. Anyhow yeah in that case you should paint it black because the green doesn't work with the color scheme you got going right now. Im thinking if you get some paint thinner it would only be a couple hours work to get the old paint off no sanding required, all the panted panels are straight so it shouldn't take that long to do. It seems your working on a budget and this is the cheapest mod you can do.
