Well this is my first attempt. Everything i have learnt/done is from this and associated sites.
Specs are;
Thermaltake Kandalf case
Asus Commando motherboard
Intel C2D E6420
2 gig Geil Ultra DDR2
C drive 2X36gb raptors (rail0)
Sapphire X1950pro 512mb PCI-E VGA Card
OCZ ram cooler
Custom water cooling;
CPU block Aqua Computer Cuplex XT DI 775
Eheim - 1250 pump
Black Ice Xtreme Radiator 120mm Radiator with noctua fan
Swiftech MCR220QP 2 x 120mm Radiator with 2 X Thermaltake led fans
Criticool Power Plant Relay Card
Masterkleer 7/16" Tubing
Cape Coolplex 25cm Reservoir (uv led on order).
Smoothy F1 Water 1Lt UV Invisible Blue coolant.
I lika a clear work bench
The dry run.
Up and running.
All done.
Just need to get the UV lights + the res led and the long sata cables to be delivered.
Specs are;
Intel C2D E6420
OCZ ram cooler
Eheim - 1250 pump
The dry run.
Up and running.
All done.
