BigDaddyKong
Active member
I picked up an XSPC Extreme AX360 kit and a 900D to try my hand at using a a full blown water cooled computer.
After getting a lot of inspiration from here, this is the start of my project.
I am using the XSPC AX360 with dual D5 bay res.
My favorite part of all this is the Aquaero 6 Pro. I wanted the XT, but they were sold out, and going to take over a month to get one in.
And just to give Tom a little chest pain, here is a little back door action.
Unfortunately, I need to work on class work, so I must stop for a few days.
I have an NZXT LED light kit I plan to install. I am going to stealth mod a BR drive and replace the temp drive I have stuck in the slot. I need to order some fan extension cables for the front fans, I was surprised Corsair did not make them longer. The Corsair 140 in the rear is making an annoying clicking sound when I slow it down from the mobo, so I think I am going to look for a replacement for that.
Future plans are to pick up an Aquaero 5 LT and slave it to the 6 Pro so I can control all the 3 pin case fans. Next year when new GPU's are released to make a worthy upgrade over my 7970's, I will pick up a set with full water blocks, and add a 480 in the bottom. I would also like to modify the power supply cover from the HAF X to work in the bottom of the 900D to cover up the power supply wires, and make a cover for the back of the drive bay to hide my tubing. That is the biggest downfall of going with a bay res. You need some slack to pull it out and fill it, so you can't make all the lines tight.
With a little testing, my temps are pretty good. For some strange reason, my GPU's are actually cooler in this case than my HAF X, buy 7C. My 3770K at 4.5ghz is running at 66C after an hour of P95. in game, it seldom breaks 45C. That's with SP120's running at 1200RPM.
