Mr. Smith
...refuses to run at its rated 1066 speed. Are they duds?
I want to get the most out of this ram with my current setup - it's not exactly cheap ram and I thought it might even run higher than 1066.
The aw9d-max doesn't have a default 1066 ram speed in the bios, 800 is the highest. Leaving the latency at stock 5-5-5-15 I knock up the cpu clock, which in turns increases the ram frequency. Whenever I do this, regardless of which speed/divider I use (533/1:1, 667/4:5, 800/2:3) if the ram frequency touches 950mhz+ it isn't stable.
My current oc I have my cpu at 370*9, the ram at 4:5 divider on 667 - which makes them run at approx 945mhz. This is stable.
I tried a variety of settings aiming for the ram to run around 1050mhz - it simply won't boot. I have to unplug the power for a min and reset everything in the bios again.
I'm getting frustrated as I'm positive my cpu can clock higher and the whole point of me shelling out the £££ for this ram is so I could have a nice oc with no bottleneck... I guess I am moaning about just over 100-ish-mhz of ram speed but, it should run at 1066, maybe higher...
Any suggestions?
Any suggestions?
