inFamousTyy
Need Mobo advice - 1st PC Build
Hi guys. I'm completely new to the forums here at oc3d. This website was referred to me by a friend and I could really use some advice from more experienced builders.
I'm really stuck on what motherboard to buy.. let alone what mobo to even look at. I researched a ton but I'm still pretty confused. From what I've read, mobos are the most difficult to shop for. That being said, my CPU and GPU I have already picked out:
Intel Core i5 6600k Skylake
Nvidia GTX 980 (MSI vs EVGA vs Gigabyte) - Another recommendation please?
With these two parts in mind, I could really use some recommendations. I would like for my motherboard to have onboard 802.11ac WIFI, unless you all really recommend buying my own PCI WIFI piece or a WIFI USB adapter.. these are the things that are in my mind and I appreciate everyone's input in ahead of time. Won't a PCI WIFI card take up a PCIe lane on the mobo, and if so will that limit me?
No budget for the mobo.. that being said I don't want to drop an arm and a leg on it. Also, I want a mobo that is future-proof if you know what I mean.
Thank you.
Thank you.
