Multiple Networks problems
Mathius
I'm finding that I need to do this everytime I turn on my PC...
What would be great is if I could get the Networks and Sharing Center to only detect the 'Network' and not multiple.
Its probably something simple I'm missing, but cant for the life of me figure it out.
EDIT,
Snortan - DHCP was already at Automatic..... but I've set the ##Id_String to Delayed Start and will post findings tomorrow when I reboot.
Press the start button and type
services.msc
press enter and look for DHCP Client, double click it and check that the startup type is set to automatic, apply, ok, reboot and see if it helps.
If that doesn't help go again in services.msc and look for Bonjour Service, (it may also be called ##Id_String2.6844F930_1628_4223_B5CC_5BB94B879762##) double click it, stop it and choose Automatic (delayed start) for startup type, apply, ok and reboot.
If that doesn't work then goto your router page, find your pc and assign it a static ip. Then if you set it to auto it will automatically assign it the ip you have set on your router. Then reboot and you should be goochi
