bartosz.bruhn
I have a problem with high temps on my MSI RTX 2080Ti Sea Hawk EK (MSI card with pre-instaled EKWB watreblock on GPU). I have install all in new loop, with SE 280mm radiator and D5 pomp. Whole build with Polish comment you can find on yt:
https://youtu.be/HY86An4OfJE
Whole loop was connect outside of case, all parts was move around and "shaked", additional pipe for air to go out on top of res.
After 30 secend on Furemark I have 78 C on GPU. Radiator is going a little hot after 5 min, but with this temps on GPU it should be fire on Radiator.
Pump is going on max, is not connected to PWM conenctor.
It going to RMA, couse I cant remve block form card. Warranty sticker on one of four skrews near GPU, but ather 3 of them I could move almost with my fingers
Is it possible that MSI card form factor with block, and maybe they forget to remove sticker from block in factory
Thanks for any advice, it's my first open loop. Tomorrow will get GTX 1080 with proper working blok.
