People seem to have problems with this board: agp lock, memory, serial ata
This is a pretty good board for the price, these are just some things I've learned:
- if you have sata hdd and plan on ocing, do not buy this
- check to see if your ram was tested for the board before you get it
- keep ht bus less than 1000 mhz for ocing
- the agp lock does work with bios newer than 3.2
- use clockgen Asus AV8 to see if agp/pci lock is working
- oc through bios
- oc through bios
