Hey,
So my mobo - ASUS Maximus Extreme - does not set the voltages to what it ought to be when i set them manually in the BIOS-
But, there seems to be a pattern -
For instance, with the DRAM voltage - whatever I set the voltage to, the actual voltage will be 0.08V higher.
This applies for all the other voltage settings -
Is this normal?
I have tried changing the BIOS, no luck.
Should I get the board RMA'd? Or is it a PSU problem - I have a 650W OCZ ModXtream PSU.
Is this normal?
