Motherboard Recommendation
memske
My local distributor has stopped getting the P8P67 series motherboards when I was going to get a P8P67 Pro.
Can you guys offer me advice on what motherboard to get instead? I live in New Zealand so ASRock motherboards are usually either not available or more expensive than their ASUS/Gigabyte counterparts. To go with a 2500k and Crucial (4GBx2), Ballistix DDR3 PC3-12800.
Dunno if you can get MSI but my C43 was dirt cheap! and it works great just as-long as you don't want to SLI/Xfire then it works great!
I found a place where I can get Asrock Z68 Extreme4! For only $30ish more expensive than the P8P67 Pro and like $50 cheaper than the ASUS P8Z68-V PRO.
I see these motherboards are highly recommended.
Can't find that exact motherboard. I have nothing against anything brand. I'm still open to suggestions just from what I've read that ASRock motherboard is the best bang for buck / performance.
I avoid ASRock, have not had good experiences with their boards in the past. As said above, check out the big three. I prefer Gigabyte personally, but ASUS and MSI have good boards too.
