Monsoon Chaingun fittings
Sypherian
simple question really
Have any of you guys used these fittings? I want to use them in a upcoming build i'm doing on the haswell refresh with a Z97 board.
So any experience on them good or bad do's and don't so on and so forth
And thx for helping out
Sypherian
been using the original monsoons since shortly after release the chainguns are just different in look but same process of installing and mine have been great no issues at all.
THX for the help guys :) but i was looking for some specifics on the Chainguns. I've read/heard that they are a little bit bigger than the free center fittings, as far as I've read you can't use a tool (at least not the free center tool to my knowledge) to tighten the compression ring, therefor it is bigger so it should be doable by hands. But I'm no way sure anyways I'll find out eventually in June when i order all my parts :)
That would be a really great idea, the only problem is that watercooling shops are very limited in Denmark so allmost all of the things will be ordered from Germany or the UK, so it would end up being pricey having to order fittings after everything else has been received.
been considering Overclockers.co.uk since they have all the things i need.
I'll just take my chances with the size on the fittings, I was gonna build it with 19/13 tubing but i could reconsider smaller tubing.
