Mitch's first PC build here
Mitch091
Hey guys, I am a new member and and first time builder. I currently have a Asus G73J series laptop and just want to get back into gaming desktops again. So here's my build all parts from Newegg. All I mostly do is gaming and surfing web.
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119160 $139.00
ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157265 $189.00
EVGA DS Superclocked 015-P3-1587-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130658 $499.99
CORSAIR Enthusiast Series TX850M 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Modular High Performance Power Supply
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139029 $149.99
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115070 $329.99
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103065 $39.99
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233147 $81.99
Seagate ST310005N1A1AS-RK 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148321 $179.99
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA 12X Blu-ray Burner with Blu-ray 3D feature IHBS112-29 - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106346 $109.99
And heres the stuff that probably doesn't matter to much
RAZER Black USB Wired BlackWidow Ultimate Mechanical Gaming Keyboard
http://www.newegg.ca/Product/Product.aspx?Item=N82E16823114012 $129.99
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) W/Speakers
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236052 $179.99
RAZER Black 1 x Wheel USB Optical/Laser 6400 dpi Imperator 2012 Expert Ergonomic Gaming Mouse
http://www.newegg.ca/Product/Product.aspx?Item=N82E16826153079 $79.99
Total price came to $2111.89.00 before taxes and shipping. For just the tower I'm under my budget
Thats my build. The idea behind this build was not having to update the computer for a few years yet still be ready for future updates and to be able to play the new games at top specs. Eventually I want to maybe get 3 monitors hooked up to get that awesome gaming view. Let me know what you guys think. I am new at this and did just a bit of research before deciding on these items. Thank you all for your time have a great day
I will keep you updated on what I decide to get. I expect to start buying these items by Feb 15/2012
No CPU cooler...? Or are you going with stock?
No I will be getting one just showing the basic parts I'm looking to get first then aftermarket fans after. I can get enough info on which fan I should use on Newegg on the feedback.
