Is anyone else around here dumb enough to be running mismatched GPUs in Crossfire and OCing them? I'm running a pair of Sapphire 7950's, one is a 7950 reference PCB, the other based on the 7970 PCB. Both cards draw different voltages, and I suspect one of them is a crappy overclocker. Trying to OC these things as a pair restricts me to 1050mhz core (which I guess isn't *too* bad).
Anyone else in that situation? Do you set the OC settings as a pair, or can you do that individually without sacrificing stability?
