Minor Update
daniSAUR
Hey guys,
I've just purchased a new case (CM690 II Adv. thanks to MSm2 :D) and PA120.2 and I wanted to do a minor update on the barbs and hoses.
Currently I have Feser white 3/8" ID - 1/2" OD pipes and i wanted to see recommendation from you all. :) Current setup is:
CPU block: Swiftech Apogee
GPU block: EK-FC88
Pump: Laing DDC Ultra Pump with EK Derlin Top
Rads: 1x XSPC RS120, 1x XSPC RS240 (going to replace RS120 with PA120.2 :) )
Tubing: Feser white 3/8" ID 1/2" OD
Fans: 2x Slim Yate Loon, 1x Yate Loon (all 120mm)
So for the time being it's barbs and tubing I'm really aiming for. Little face-lift if anything. :D
Thanks in advance!
Dani
Will do Msm2 :D
Case should be here Monday, along with the PA120.2.
I've had a few compression fittings before but was never 100% certain on... well, sounds stupid but I wasn't really aware on how to install them :p So I may get some of them as I've seen how they're done up.
Recommendations away peeps! :)
