remember300
Active member
Well you should be proud.... I am seriously investigating this idea, I really wanted something unique to add to this small form factor build aside from the fact that its quite possibly the smallest... now you have given me the perfect IDEA!!! still have no idea how feasible this is yet
for reliability id not mess with springs, except to add loan to the flaps so they dont open when transporting, as you said you wanted to take your case places
a dummy load with a wire going to the rod in a motor wrapped around it then going to the flaps to open up, id have to build a circuit or something to open at a set temp, could possibly rig an aurduino to do this, which i have lying around the house and some temp sensors from my cooling node which i dont use, would be better if i could get it to read from the cpu temp though. and once circuit is done leds are no problem
