name='Brooksie' said:muahahahaha towel trick worked![]()
name='PP Mguire' said:Seriously. If you wouldnt wrap your PC in towels then why would you wrap a machine with more cooling problems then a Prescott P4 in towels?
name='Rastalovich' said:What`s the towel deal ? Got 2 fudged ones that crapped the day after their warranties went, both replacements.
name='Brooksie' said:wrap it 2 towels for 15 mins, which blocks all air coming out so it overheats.. then once 15 mins is over let it cool down for 15 then it should work
name='Rastalovich' said:I don`t think so from a 360 mobo that`s already busted. That`d probably require some precision soldering first.
From new tho, I know the exterior fanage addons only prolong the impending disaster - pushing u further out of warranty date.
Warping the mobo to make contacts.
You wont be saying that when the warranty is over and you do that and cant get it replaced. Take care of it now and it will probably last longer. Get over it, / end.because its a proven quick fix,sh1t,get over it.
name='Brooksie' said:Yeah thus making it work![]()
name='ali_james' said:Is it possible to mod the 360 to put any more/better fans in it? I get what the towel trick is doing but surely not going to be a permenant solution.
