Matx Dragon Slayer Rig
SEBAR
This is a budget system I have been tinkering around with. This system is always evolving as money becomes available. I am trying to work out whether or not I can cram a custom CPU loop in this case.
Nice.
I love the way you've mounted that Antec CPU cooler - definitely the best place for it.
Nice.
Thanks, it is impossible to tell but this is set up with push/pull fans. The other fan is mounted behind the front bezel.
I initially set the H20 with the rad on the roof of my dragon slayer case with the stock fan. The temps went down from my zalman air cooler but the H20 was to loud for me. I tried several different setups trying to find the best noise/performance. I tried front mounted rad with enermax magma pushing air through the rad, very loud and minimal improvement over stock (Idle temps approx 33 degrees Celsius, load temps in the low 60 degrees Celsius). I tried top mounted rad with Nautua NF-P14 pulling air through the rad, this set up worked really well and was very quiet (idle at 30 degrees Celsius, load at 58 degrees Celsius). I tried front mounted rad with NF-P14 pushing and NF-P12 pulling, this set up worked the best and was quiet at full load and almost silent at idle (idle at 27 degrees Celsius, load at 50 degrees Celsius) . Unfortunately I need those fans for my main computers NH-D14, and the cost of purchasing these fans is high. I ended up using push/pull with the rad mounted in the front of the case and two coolermaster 120 blue led fans in push pull 9idle at 28 degrees Celsius, load at 53 degrees Celsius). The temps I get with this setup is only 3 degrees higher then with the Nauctua fans and are very quiet. These tests were done on two separate days and i did not measure the ambient temrature however, I live in an area where the temperature does not fluctuate very much and my office is always about 21 degrees Celsius.
Need some newbie help, I see some people with multiple picks of their rigs. Using the attachment function only lets me to upload 500K. What do I need to do to add more pics. I also want to add some pics of my main rig.
Any help would be much appreciated.
Update to the Dragon Slayer. Modded a window into the side panel. Easy mod, just removed the mesh fan mounts and put plexi in its place.
Dragon Slayer rig update. This has now become my full time folding rig, I have been folding on it for about 2 weeks now. The follwoing changes have been made. 1) R6850 has been replaced with a GTX 460. 2) The plexi window has been removed to allow for better airflow since this is running full load on CPU and GPU 24/7.
Nice one mate, I can see that your average has gone up massively
Thanks, I initially jsut wanted to get going and get into the top 100 for the team but I quickly got sucked in. I am even considereing building another 2600K rig to do more SMP folding.
