removing fan guards and anything else you dont need that the air gets sucked thru can reduce noise. my case used to kind of whistle untill i cut away the bits of plastic and metal i didnt need in the way of the fans, now its just a low whoosh of air blowing thru it. the level might not of changed but the sound it makes is much nicer to live with.
