a low down (might be a bit long..)
i have 2 PC's, one downstairs for family and my one in my room. i managed to 'stupidly' get a virus on my pc which wouldnt allow me to re-install windows (i have a thread about it on here somewhere) so i went out to get a new internal HD
basically, i tried to install windows from disk from startup (replaced my maxtor with the new samsung) of which it wouldnt boot and gave me a nvidia boot agent error (more on that later) so i went down to my family pc and found 2 SATA connections on the mobo which i was supprised about (a good few years old, but was good back in the day) so i plugged my samsung in and the pc booted fine onto the family hd and windows pickedup the samsung just fine
.. i then installed windows etc and got it working. then tried it on my pc... still not working! then i thought it might just be the mobo n hd not liking each other so i took the maxtor (one that boots but has a virus) downstairs, re-formatted, re-installed windows, done. tried it upstairs and boom.. nothing. keep getting error messages:
nvidia boot agent 242.0535
copyright (C) 2001-2005 nvidia corporation
copyright (C) 1997-2000 intel corporation (however my mobo is geforce and cpu is amd ??)
PXE-E61: media test failure, check cable
PXE-M0F: exiting nvidia boot agent
it then just keeps going through and through that and asking for a boot cd.
tried the mobo driver cd.. no luck, tried the xp cd.. no luck.
none of my hd boot on my pc now
fiddled with bios, bios can find and recognises the hd's, checked cables, checked xp cd works etc etc .. everything is fine! also tried multiple 'startup routines' none have worked.
thing is also... the maxtor and the samsung wont single boot on my family pc either! although they do work if i have the family hd in and my other hd as a salve, which windows picks up fine.
am i missing something on the hard drive that 'ment' to be there for boot-up? the maxtor worked before (came blank and i installed xp onto it from bios) but now it doesnt
oh and my pc is nvidia/amd, my downstairs is intel/ati so maybe i have some sort of intel/ati drivers on my new hd? although they dont work alone on my family pc anyway so this might not be the problem
any thoughts?
any thoughts?
