Macroman595
Hello and good day to you all!
I built my first computer around 2012-13 but I was new to the pc building scene and had much help with it.
I decided to build another after various problems with my first and mainly as a solo project using forums and reviews for the parts I was after and decided for myself what I wanted/was looking for.
The following makes up the bulk of this new build:
Today I decided to put it all together:
Used the motherboard box and desk as test bench.
Everything was fine, so I added the temporary GPU.
No problems after I ran the rig with the GPU installed. Then installed everything I currently have into the Fractal Case. I added the GPU after.
Further testing resulted in no problems. Connected the big tv and booted the rig into BIOS.
Added a temporary storage device and the GPU. Both will be replaced later on.
The 2 fans are fractal design silent series and came with the case. A third on is behind the front removable filter.
Closed the case up and let it ran some more. Bios was reading CPU temps of ~40c. (Stock Cooler)
I would like to give a big thank you to the OC3D community for your advice and support.
Plans in planning:
- Fractal Design Arc Midi R2
- MSI Z87-GD65 gaming
- Intel Core i5 4670k
- Corsair AX860 (Modular)
- Corsair Vengeance LP 8GB
Plans in planning:
- Replace stock cooler with either a better air or liquid cooler.
- Possiblity of overclocking
- Move a Radeon 7870 Tahiti LE from first build to this one.
- Re-use SSD in current build as boot drive.
- Install new OS to SSD
- Mass storage drive will also be transferred over
- Swap the Fractal design fans for Corsair fans from current build
