Mach II not recognised (bis)
thorgal
Hey guys,
First post here but I've been around for a while looking around ;)
Anyway : Yesterday I finished reinstalling my Mach IIGT unit but now I can't seem to connect it properly to my pc : windows doesn't recognise the unit.
Previously I had no trouble installing it on a DFI Ultra-D, but now on my new SLI-D I can't get it to work.
When I connect the unit to the usb-header I get an error message : "unknown device" which keeps blinking in my system tray.
When I look into the device manager I see an unknown device under the USB-controller menu. But no mentioning of a prometeia unit or anything.
I tried recombining the usb cables but to no avail.
Is my mach II controller broken ? Is there anything I can try ?
Thanks a lot for any help !
Grtz,
Thorgal
Thanks,
The second link you gave was helpful indeed, the first I already read !
I got it to work at last, but there seems to be a mixup with the wiring on my mainboard or with the wires from the unit : I use the combination "white-green-red-black" now and it works (it should be red-white-green-black but that doesn't work)
Thanks again for the quick reply !
Thorgal
