M-Itx Motherboards
joey117
I am going to buying a bit fenix prodigy and i have been told you can't put a mini atx board in then so i am looking a advise on a good board that can use a 3930k and a gtx 690
any help would good thanks
I havent seen any itx boards with a 2011 socket.
The best you can really do is a 3770k on a P8Z77-I deluxe.
I'm not sure if it would like having a 690, but it's the best I can suggest.
X79 ITX? c'mon... so un-necessary. CPU with 40 pci-e lanes and only will use 16? the RAM/GPU
will use up 50% of the real estate and there wont be enough for anything else IMPORTANT.
that will be such a wasted space of power. jacking $1000 of needed hardware in a $80 case,
just not fesible. stick with the Z77/68 boards and related CPUs and that'll be a smokin' lil box..
airdeano
there is a small field of mATX 2011 motherboards
ASUS Rampage IV Gene
ASRock Extreme4-M
MSI X79MA-GD45
with no Giggy submission, yet... are i know of, so far...
airdeano
