Reloaded2
Hey,
This is more of a question and advice then anything. Basically in my current system I have an i5 2500k (@4.4GHz/1.31v) cooled by a H60 2013.
The problem is the H60 is too loud in my system. My guess is its the pump because its using a noctua NF 12 and the GPU makes no noise when idle and the system fans are on noctua 140mm low noise adapters.
So I wanted to replace this cooler with a nice and quiet CPU cooler (especially at idle). I have a Fractal Design S case so it has plenty of space for the big coolers. Preferably I want it black. This leads to the question. I was looking at the Dark Rock Pro 3 but I wanted to know will it have enough ram clearance to fit and what are your recommendations on coolers. Budget is around £80. I am using Vengence Pro ram. See picture to get an idea of what I'm talking about.
http://imgur.com/a/Dq4so
