I want to build a new system, but I have not found a decent case for my project.
Since I want it to be über quiet, it's kind of hard for me to pick the right one.
I'm pondering to pick the Fractal Design Define R4.
The build:
i7 4790K
Asrock Z97 extreme6
Cooler Master Hyper 212 evo
Corsair RM1000
Nvidia GTX 780Ti
No plans to overclock, no plans for watercooling and no need for a window on sidepanel.
I fear that a super low noise case will bring low airflow into the case.
Is there any other good quiet pc case with good airflow (in the +50/-50$ price range)?
Should I just take the R4?
P.S.:
if I don't plan to overclock, should I go for the normal i7 4790?
Afterall the K one will run on 4,4Ghz(with turbo), and the normal one on 3,6Ghz.
The build:
i7 4790K
Asrock Z97 extreme6
Corsair RM1000
Nvidia GTX 780Ti
P.S.:
