Low firestrike score
crap-at-games
Hi guys ive got a evga 780ti sc acx card
Ive got 3dmark on steam and when it launches i highlight the Launch 3dmark (Force 64 bit) and when i run firestrike im getting a score of 6944 i thought that it would be higher than this is there any thing im missing here
Heres a link if it works lol
http://www.3dmark.com/3dm/8958813?
Any help will be most appreciated thanks
Have you over clocked your card at all, because I got a big jump when I did. And which fire strike did you do.
Also are you running Extreme or normal FS? If it's extreme then it's probably about right. I have a 980 and get around mid 7K
What temps are you getting on the card, run afterburner or something to record what your card is doing during the runs.
Hmmm my 760 does a score of 5972 on the normal Firestrike test. On ultra it doesn't even do 900 (887). Doesn't sound like the 780 Ti is on a 'something is broken' level of low, but it's also not high at all considering the card that it is.
From your specs nothing seems out of the ordinary and when I check the Nvidia page it seems you're running the latest drivers?
10.18.13.5850
Have you tried an earlier driver?
What other expansion cards do you use in which slots?
I think something isn't right with your GPU drivers. I've compared it with my result (both cpu and GPU at stock, although i've only taken graphical scores into account) and something is a bit off.What are the temperatures for the gpu under load like?
hmm isnt there some bug about G sync dragging down fps/results?
run the test again without Gsync switched on and see if there is an improvement.
I would definitely disable G-Sync, the CPU score seems acceptable so it does point to a bit of a problem with the card. Are you running afterburner or any such utility.
Get GPU-Z running in the background and prinstcreen all of the sensors tab after a 3d mark run so we can see how the card is boosting.
JR
just ran it again
