Luscious
Hope somebody can chime in with some suggestions for a small (pun intended) issue I'm having.
Many sites do SSD reviews, but few publish detailed specs on drive size. I have a HP 210 Mini netbook that I'd like to upgrade to a SSD. My problem is that I cannot fit a standard 9.5mm tall drive as HP has designed the Mini to fit only drives with a 7mm z-height.
I've tried doing some online research, but have been able to locate only three SSD models that are 7mm tall:
The Intel drives are listed as 9.5mm, but they come with a spacer that can be removed. It would be good to know if there are any other 7mm SSD options other than the above three.
I'd like to find out which one of these is the best buy based on low power consumption for extended battery time. I also want something with solid reliability/quality. My budget is in the sub-$400 bracket and I need a drive that is either 240GB or 256GB capacity.
Any/all help appreciated!
- Intel 520 series
- Crucial M4
- Samsung 830 series
