Do you really need sata 3 (ssds)? Otherwise, I'd just get a sata2 card because they are cheaper and fast enough for hds and (at least where I live) there are much more models with sata 2 available
Something from LSI, Adaptec or 3ware should be a good choice
waste of time and money for a multi SSD RAID.. keep it mechanical RAID. the
SSD in Win7 will have issues in garbage clusters and littered in nominal
need for that speed.
unless you are willing to dump serious dollars, ok RAID and SSD is a poor
choice.
As airdeano said, it would be very expensive and I don't think you'll benefit from such a setup in real world applications. The controller alone costs £300-£500, after adding another £500-£1000 for the ssds and you could build a very nice gaming rig instead
I think "Is there any of connect 4 because a i have 4 sata 3 port and for them to shown in you my computer as 1 big drive instade of 4 small drive ?" means something like: is there a way of connecting 4 ssds to my mainboard which has 4 sata 3 ports. I also want them to show up as 1 big drive instead of 4 small individual drives.
I think your mb has 2 intel and 2 3rd party sata 3 ports, which means you can't run four in raid. Of course they'll show up as one disk, that's kinda the idea of raid (along with speed or security)
Tbh if you know that little about raid you shouldn't be spending any money on a raid card.
awesome..
so do you understand that a four SSD RAID is pointless?
keep it simple.. cost is easier to handle, no wasted spending and fustration on spending
gobs of cash with lil or no return on performance..
i understand by reading your posts and toms posts that it is not the way to go thanks for all the info and advise , Tom keep up the great work on youtube help alot when looking for hardware
