Well guys this is a new load tester that I have made, 4Qman and I are building a cascade and our current load tester was only good for about 150watts which will not be good enough for this load tester so I thought what I could do and have come up with this.
It has a verbal load setting with anything from 0watts right up to 500watts of which we won’t be testing this high but it is handy to have all the same, as you can see this has been made with safety in mind and has a 3amp MCB in place and full earth protection and clamp so that whatever we are testing can be earth bonded as well for added protection, this is all in line with IEE 16th edition regs.
The unit has now got to be calibrated showing what wattage is being put out to the heat source, this will be done when the cascade build has been finished as I have put a thermal cut off switch in place on this which cuts the power to the whole unit at 5c for protection, so will need some low temperatures that can hold below 5c so that I can calibrate the unit.
Anyway here are some pics for your viewing.
