Little Help..
imported_Bazza
Well, with the chiller officially becoming mine on Saturday, and with a hole load of insulation, tubing and CPU blocks.
I've got myself a Celly 347 CPU, an nVidia 7300 GT, a Foxconn 965 mobo, some Crucial Balistix, and a nice big PSU. Anyway...
Do i need to bother burning in the CPU or the GPU, or will a few instances of 3D Mark 01 and Super Pi surfice before overclocking?
Thanks in advance.
I guess it`ll naturally burn in as you clock it and run it at whatever settings you go for. CPUs need a little time to get used to whatever temperature range ur going to use them at.
I have to say i normally dive right in, test stability at stock first to make sure there's no underlying issues but other than that just give her some volts and watch her fly :)
