L Luger718 New member Feb 11, 2011 #1 it wont eat through the cpu heatspreader right? im pretty sure it wont but just checking
S SmoulderingCircuits New member Feb 11, 2011 #2 Dude why are you using lighter fluid O.O! use a tissue or a cloth if you want, but using alchahol and lighter fluid and crap - why? it's so pointless
L Luger718 New member Feb 11, 2011 #3 Fodr Kreatr said: Dude why are you using lighter fluid O.O! use a tissue or a cloth if you want, but using alchahol and lighter fluid and crap - why? it's so pointless Click to expand... nvm checked online and its good stuff works great actually used it on an old cpu heatsink stuff comes right off and it was only 2 bucks!
SieB New member Feb 11, 2011 #4 You are ok with any solvents, they will just evaporate. I prefer using nail varnish remover myself.
C Catch22.ian New member Feb 11, 2011 #6 Last time I used http://www.arcticsilver.com/arcticlean.htm - which worked well.
T TuNk77 New member Feb 12, 2011 #8 Isopropyl alcohol is the way to go, lighter fluid contains grease / fat. You can always go to the gas station and get a bottle of condensation remover, they have a contents of isopropyl
