Lian Li v2010 Water Cooled
Denis777
Hardware
CPU: Intel Core i7-950 Bloomfield 3.06GHz (4.21GHz)
M/B: Asus Rampage III Extreme
GPU: 3X EVGA GTX 465 Superclocked
GPU: 1X EVGA GTX 470 Superclocked Dedicated physX
RAM: 6X 1GB CORSAIR DOMINATOR DDR3 1600
PSU: Cooler Master Silent Pro Gold 1000W
HDD: 2X Western Digital Caviar Green 1TB
HDD: Western Digital VelociRaptor 300GB 10000 RPM
Sound: Creative Sound Blaster X-Fi Titanium Fatality
Water Cooling
CPU: EK-Supreme HF Full Nickel
M/B: EK-FB RE3 Asus Rampage III Acetal/Nickel
GPU: 4X EK-FC470 1x EK-FC470 Backplate
RAM: EK-RAM Dominator Acetal/Nickel
Radiator: Koolance 4X 120mm Black Ice Pro Compact 3X 120mm
Pump: 2X Koolance PMP-400 2X Koolance COV-RP400 Reservoir Base
Reservoir: 2X Koolance BDY-TK120 120mm
At first i were using one color which was blue
and then i though there is too much blue so i decided to use green and red
i am glad you liked it thanks
I like the dual loop with the 2 different colored coolants, looks really good.
It took a lot of custom work to make that case work with water cooling
and look nice as you can see wouldn't have to do half as much work with 800D
for example 800D already powder coated from factory, but my case i had to strip
anodized paint and then powder coat. Unfortunately 800D didn't exist when i started
my project for sure my next build would be based 800D case
Nice build and I gotta say that case looks sweet
very nice looking rig mate what are your systems full specs????
Will post full system specs very soon kinda short on time
ya need to learn to use the multi quote options mate lol simply hit multi quote button by each you want to quote then hit add reply it'll make seperations for ya simply add comment in betwen ones ya select.
just a heads up mods dont like double or triple posts
Extremely nice build. Love the coolant and the fans. Actually, I like the whole thing... Great job.
I just bought this case and was wondering how you mounted the radiator at the bottom?
Lovely rig! Brilliantly planned and nicely done! Next thing to do would be to sleeve those nasty yellow power cables! Haha
That would tie it all in
Really easy on this case all you have to do is remove hard drive cages mounted side ways and just install one facing the other way
then you can use XSPC RS/RX 120mm Series Radiator Stand brackets, but what i also did is installed 1 inch aluminum square stock
so that radiator would seat higher of the floor.
here is some pics if you have anymore question please free to ask
