Lian Li PC-Q10WX??
The_Governour
I have a possibility to pick this case up, it seems very small and would be nice to build in but so far I have not seen any build logs or photos of builds in it.
It seems that if you would use a single radiator then you would either have to place it out side and the fan on the inside to fit or?
Would a Kraken G10 fit if you would go quick water cooling just for the GPU?
Here is a video of the case.
https://www.youtube.com/watch?v=GlrejFsgVkE
I have either a 780 blower or a 760 windforce laying around, if I were to make a loop then I could expand the Fractal T12 that I have but I would say that EVEN if I used a Alphacool 30mm rad then with one fan it would block too much?
By air then I see that from the photo here then they have used a Dark Rock 3 (or is it the Pro?) and that is pretty tall, could u then fit in the kraken G10 for that 760??
Techincally, you could get away with mounting the radiator in the rear and using a not-too-big CPU cooler.
HOWEVER, the card itself becomes a 3 slot with the bracket installed on it. Seeing as this case only has 2 PCI slots that are already way in the bottom of the case, I very much doubt it'd have the extra room to accommodate the G10 bracket.
The Corsair HG10 however appears to still be a dual slot design due to the use of the blower-style fan on reference cards. And they do have a 780 version for reference PCBs.
Well for the 780 then I all ready have a waterblock so I could technically make it a loop with the Factal T12.
I just wanted to use the 760 as it gets hot as hell so I wanted the G10 bracket.
* On a side note then I see that alphacool has nexxxos water block made for the 4 gb version of the card and would it fit with my 2 gb model?? its the same rev. 2.0.
The strange thing is that Lian Li says it admits CPU coolers up to 140mm but the Dark Rock 3 is 160mm...
Now the question is Air or water? The 780 is the only one with block not being used, and the cpu that I have for this is the i3 4130 - a bit of a miss match but that is what I have to work with for now.
