LED compatible CPU Blocks
Helltech
Are there any CPU blocks out there that are aesthetically pleasing that can support LEDs? I know the Raystorm, it is what I am looking to get. I also know they EK blocks are very good but dang they are literally just "blocks" and so bland. I like the Raystorm, but I don't LOVE the Raystorm, so I want to shop around, but I can't find anything.
The Bitspower Summit EF also supports LEDs but I don't know anything about the performance. Raystorm is a great option though. Personally, I stay away from anything EK, especially after so many of their customers got burnt about a year ago with the flaking nickel issue on their waterblocks.
You could always just take a 3mm drill bit and drill into the side 4-5mm on any block with a plexi top with enough meat round the edges
The Raystorm is an awesome performer, scores close to the new Koolance 380, with great flow rates & temps. If you choose another block you can always mount LEDs under the mounting plate close to the block for a nice backlit effect.
Well I wouldn't go with EK anyway because of the fact I think they look bland.
I'm not 100 percent of that look of the Raystorm which is why I'm shopping around.
I don't plan on drilling any holes in any blocks, as much as I like modding cases, I don't feel comfortable modding a block.
Yeah, I could just do backlighting with LEDs, but I'm shopping around.
I really like the black and white Swiftech Apogee HD, its probably my favorite looking block.
