Scoob
Active member
Hi all,
Just been building my WC loop - build log of sorts up soon - and I've run into a little problem.
My rad is a Phobya 1080 (9x120 in effect) and it's mounted in an external chassis - all very neat and tidy. During leak testing I had the odd drip around some of the fittings - namely the Koolance QDC to Phobya compression fitting, those two aren't very compatible. A small Phobya extension placed in between gave me a good seal though.
As leak testing was done and the thing passed after sorting the above, I popped the proper coolant in, tested again for ages, before finally using the PC. Have been using it for a couple of days without issues.
Last night I'd just finished on the PC for the evening having been gaming and I noticed a small puddle of coolant under one of the compression fittings connected to the rad. It's the "IN" fitting so is directly after the pump (a variable speed D5, set on 5) I thought at first that the compression had come a little loose - I've noticed that this isn't uncommon, i.e. you get the compression TIGHT then the low temperature of the coolant once you start running it make it feel slightly loose. Anyway, I checked the hose-side of the compression and managed to get another 8th turn (by hand) on it, the rad-side of the compression was good.
I cleaned everything up so it was dry, and left the loop running (PC off) for around 15 minutes with a bit of loo roll under the compression in questions. After this time I could see that I had about one or two drops on the loo roll, so I'd not fixed the issue.
I QDC'd the res assembly and popped it on my desk, it was then I noticed the beading of water NOT around the compression (but running down it) rather it started from the RADIATOR. Balls.
Basically my rad is mounted vertically with the fittings at the bottom. The bits where you screw in your fittings are, I assume, welded in during production. It seems that there's a micro-fracture around this fitting causing it to seep slightly - more when under pressure from the pump of course.
Not sure if this is something, if not common, at least know to happen. I.e. a small manufacturing defect only showing up after a couple of days of running.
I know I've not done any damage as I've done everything finger-tight throughout - in fact that's the reason I thought it was likely just a slightly loose compression at first. Also, as anyone who's done it will know, it's quite tricky to tighten the block end of a 90 degree rotary as you've not got much area to grip - certainly not on the Phobya fittings I use. This added to my thought that it likely wasn't quite tight enough.
I suppose it's possible that the rad took a knock at some point, though the packaging seemed fine with no evidence of it being bounced. It's certainly not been dropped by me as it was placed in the rad chassis soon after I took it out of its box, so it's been safely in that since - it was the first item I added of course as the shrouds, fans, fittings, res pump all mount on the chassis too.
So, I have a leaky rad...I'll have to see what the shop I bought all my bits from say on Monday. I guess it'll have to be replaced as it's not even a week old yet - got it all Tuesday last week. If I'd been running it for months I'd likely just try to patch it with something...but as it's brand new it really should be replaced...what a pain!
I'd been really quite cheerful until this - a job well done you know? Just started enjoying the SILENCE during gaming, plus I thought it all looked quite smart - if not LED bling just yet lol.
Thoughts?
Scoob.
Thoughts?
Scoob.
