spazgadget
Hey OC3D!
Here's the new build that I am considering. Both the name and colour scheme of the build are based upon the 'Lancelot' Kinghtmare/Frame from the anime Code Geass, which is a white, gold and black scheme. I found that the Bitfenix Shinobi, in white with the custom gold trim suited this scheme perfectly.
Here is the full planned spec:
CPU - AMD FX-6300
Motherboard - Asrock 970 Pro3 AM3+
RAM - Teamgroup Xtreem LV 8GB (2x4GB ) 2133MHz
GPU - ASUS AMD HD 7850 1GB
HDD - Seagate 500GB SATA-III 7200RPM
PSU - Corsair 430W CXM Modular power supply
CPU cooler - Thermaltake Frio
All-in-all, the system costs around £500, and I would like to keep it at about that price range (Or hopefully less!). Thoughts on this system, and any improvements to the spec would be greatly appreciated!
~Spazgadget
CPU - AMD FX-6300
~Spazgadget
