just playin about :-)
Looking good so far - Look up some settings for a64 tweaker and do some tweaks like realtime and end explorer and run in diagnostic mode in msconfig and possibly the ricky trick. You'll soon be under 24s and helping the EP average even more. Make sure you submit to mbot.
name='Grov' said:
Wow 3500mhz. 3d stable? That is sweet.
What week 57 is that cause my week 16 one does superpi 1M at 3600Mhz with less voltage (1.63) and worse cooling (R507 Mach) I'm sure there's more to come with a chilly and 1.7V.
EDIT: Just remembered that's a week 22 ;) - Still I'm sure you can do better under a chilly. What Vdimm have you gone up to so far?
Hopefully there is a little more to squeeze out of it.
I hope so but most 57's dont seem to clock any higher than SD FX55's (on phae coolign of course) no matter what cooling you use there are only two people here I know can break 3.6Ghz - Gollum is one, McMad is the other and they both seem to have week 16 units.
To me it was the biggest disappointment to find that was the case with FX57's, especially considering the price, everyone on phase should be able to achieve 3.7Ghz.
However, I think on water or air cooling, because the clocks are achieved using less volts (and hence cooler) there is a more appropriate clock difference between the SD FX55 and the FX57 which part justifies the higher purchase price.
