My mini firdge has gone up the duff and having some spare peltiers and a 360W psu means I thought it would be fun to "pimp" it from 40W to 120W
Of course with some cutting, banging, crashing and swearing it sees temps only just below ambient because the cooler is cast aluminium and tiny. More heat away from the hotside means lower temps coldside and because the thermal load is negliable because its a fridge I can get closer to the 69dT quoted. I have 18A of 12V goodness and 120W TEC so how do I cool the hotside instead of using the crappy aluminium thing, I hear you cry.
Coolermaster Aquagate R80. A "self-contained" watercooling system powered by a fan connector.
Bought some 5 years ago for my Athlon XP based shuttle it has been sat doing sod all since i upgraded 4.5years ago
So now, in the timely tradition of OC3D where cooling excess is necessary I'm smacking, cutting, filing and soldering this bugger together just for poo and chuckles.
It wont be the perfect peltier system but with no thermal load it should kick the crap out of what it used to do. I will update with pictures when the dremel is charged
