JDM_GT WC TJ11 AMD RIG
JDM_GT
hey guys thought id finally join the forums, just like to share my next build with everyone, im a aussie and live in QLD so wc is the only way to go, this is my current rig,
CASE: Coolermaster storm sniper BE With a window instead.
CPU: amd phenom 2 965 BE.
MOBO: ASUS crosshair 4 formula.
RAM: 4x2gb G Skill PI's 2200 running at 1800 9.9.9.24.2t
GRAPHICS: ATI 5970 and 5850 Tri-Fire.
PSU: coolermaster 1000w silent pro gold.
STORAGE: boot is a 50gb vertex 2 and storage is 2x WD 1T Blacks and back up is WD 2T green.
COOLING: Swiftech apogee XT cpu block, swiftech mcp655 pump, swiftech micro res, 3x swiftech 120.2 rads, tygon tubing.
here are some pics of how it is atm, and some couple of teaser pics, I just ordered some new wc gear and ill post pics when i get it. dont want to give to much away. but i do plan on 2 6990 on water. ps i just gave up my motorbike for this hobby to take center stage. hope you enjoy.
and sorry for the iphone 3gs pics.
I think they are AudioEngine A2, i could be wrong though.
they are edifier, i think the model is z5500 ass kickers or somthing like that... hehe, they are edifier s730, 2.1, the sub is 180w rms and the fronts are 75w rms each. they really are soooo fkn clear and loud, one of the best things ive ever bought.
just ordered the fans and rads for my tj11 build, now i have to wait... plus still waiting on my fittings i ordered a week ago, ill post pics when i get the gear.
$AU600 for the tj11,
$AU615 for fittings/coolant/tubing/fan controller,
$AU420 for fans and rads.
I have a res and cpu block, only thing left is two 6990's and matching waterblocks.
got some mail today, but the fkn fan controller is silver not black as i ordered. but anyway PICS PICS PICS.....
nice build man....just a sudjestion....if you replace those noctuas between your rads with a rad shroud and used those noctuas as "pull fans" you may see a drop in temps 3-6 celcius.... fun hobby tho huh??? check out my current build "stark contrast" in the work logs...
bTx
bTx
thx for that, but ill only be using that case/setup for a few more weeks then going over to the tj11 with sr1 280/ sr1 560.
Done for now.. need more comp fittings and cable splitters and extensions, prob upgrade my psu (prob silverstone gold 1200) when i buy the 6990's, now after ive finished this build i can say now it was a bitch. lol anything i wanted to do i had to change and think very hard about it, even though its a massive case that bottom compartment was filled to the brim. not a fan of the fan controller either i think 1 channel is stuffed aswell, it doesnt slow the fan down, looking at the mCubed T-Balancer bigNG, anyway here is my nice clear bright ipnone pics, ill get my mates dslr and get some nice shots, there are no lights atm, no more molex left.
i found some plastic in the waterblock when i pulled it apart, looks like from a drill thread.
the 180mm fans in the tj11 make a quiet droning noise, its really annoying, going to put them on the controller and slow them down more, hope this will help.
enjoy, tips, comments much appreciated.
no gpu blocks cause im saving for 2x 6990's then waterblocks on them
